TwinTurbo.NET: Nissan 300ZX forum - Jumps to right under the Top line
sandisc
on August 24, 2021 at 8:12 AM
Re: Cooling Gauge fine while driving then overheats after restar
posted by Kvert
on August 23, 2021 at 10:40 PM
Then will recede back to operating temp once the pump has the chance to start moving water around it seems.
sandisc
19:00:37 08/22/21
Heat soak? It's not uncommon for coolant temps to rise 20°F
LitlElvis
11:17:11 08/23/21
What brand water pump?
FrozTTy
14:27:37 08/23/21
Re: What brand water pump?
sandisc
18:48:32 08/23/21
The coolant overflow system will self-bleed over several run
LitlElvis
10:46:06 08/24/21
Kvert
22:40:37 08/23/21
Jumps to right under the Top line -
sandisc
08:12:41 08/24/21
Re: Jumps to right under the Top line
Kvert
10:58:31 08/26/21
Burp it and make sure to use AF/water mix...
Ted (92TT)
15:00:52 08/24/21
Went through that process this morning
sandisc
10:05:33 08/25/21
